Stalling volvo 740
Old Jan 26, 2007 | 02:49 AM
PaoPao's Avatar
Default Stalling volvo 740
When my 1994 volvo 740's engine warms up the car will sometimes stall. I brought it to a repair shop, the filters were replaced. And it did worked. But weeks later, i'm again dealing with the same problem. It's not the thermostat or the spark plug either. Hope you could help me with this.
Old Jan 26, 2007 | 03:15 AM
sandders08's Avatar
Default RE: Stalling volvo 740
I had same problem on my Volvo 740. In my case, it is a choke valve. The valve didn't open when warm because the sensor is not sending a signal back to open again. The problem was solved when i replaced my sensor which is not really working normally. You can check both sensor and valve for a good start.
Old Jan 26, 2007 | 08:49 PM
Does your car have a engine speed sensor?
How old is the fuel pump relay?
volvoinct
Jun 8, 2022 03:30 PM
~ViciousVolvo~
Apr 9, 2008 06:41 PM
lagwagin
Nov 4, 2007 01:34 AM
Tligon
Jan 22, 2006 07:36 PM
junkmorning
Mar 23, 2005 10:51 PM
