Starter starts and stops while key turned
Old Mar 25, 2007 | 07:13 AM
Daffydavid's Avatar
Default Starter starts and stops while key turned
I put a brand new starter in because the engine used to do this before and then the starter stopped completely(only got click from solenoid). Does anyone think that the engine is partly seized or do I have an electrical gremlin? Have already inspected battery cables and the battery is good too.
Old Mar 25, 2007 | 07:39 PM
billofdurham's Avatar
Default RE: Starter starts and stops while key turned
I wouldn't think the engine is partly seized.
Apart from inspecting the battery leads did you clean the connections? Both battery terminals should receive treatment and the earth (ground) lead where it meets the body often goes bad and needs a good clean. Also check the ground strap from the engine/gearbox to the chassis. As a last resort put new leads on.
Have you had the battery tested or do you just think it is OK?
Try jumping a lead from the battery positive direct to the solenoid out terminal to see if the starter works from that. You could have bad wiring between the ignition switch and the solenoid.
Old Mar 26, 2007 | 05:28 AM
Daffydavid's Avatar
The battery is less than 1 year old and I tested all the connections and cables and they all test OK. This problem comes and goes. Yesterday I couldn'y get it to start, today it started right away.
88 240
91 Eagle Talon TSI AWD tricked out.
UserMG
Dec 21, 2014 09:48 AM
krt919
Nov 29, 2014 03:50 PM
BilyBob
Dec 31, 2013 10:59 AM
KIDSS70
Dec 19, 2010 09:39 PM
