Starting problems in mild weather 1992 240
Old Jan 1, 2014 | 05:05 PM
carashea's Avatar
Default Starting problems in mild weather 1992 240
This forum has been a wonderful place for advice and troubleshooting on my 240's. My 1992 has an issue that neither I nor any mechanic I've gone to have been able to figure out, and I've not yet seen it addressed anywhere. She won't start when the weather is mild and especially if it is damp out. If the temp outside is under 35 or so, or above 65, there are no problems. But anywhere in between, it takes forever to get her going and then she runs rough for the first 10 minutes or so. I've recently replaced the MAF and fuel pressure regulator.
Old Jan 2, 2014 | 01:38 AM
lev's Avatar
lev
You need a new Coolant Temperature Sensor and a new mechanic.
Old Jan 2, 2014 | 02:44 AM
carashea's Avatar
The coolant temp sensor has also been replaced -- but I'm curious as to why that would make a difference only when the weather is cool? Keeping my 240's on the road continues to be a learning experience It is fine when it is cold outside, or hot, but not in between.
Old Jan 2, 2014 | 10:02 AM
lev's Avatar
lev
The CTS sends a signal to the ECU determining how much fuel is needed, more when cold, less when already warm. The faulty sensor can be out of range on either side signaling who knows what. Hard cold starts are a classic sign of a bad CTS. If you replaced it with an off brand, it may still be bad. These days we see a lot of substandard parts on the aftermarket: people replace them and assume a new part is good which isn't necessarily so.
petes99xc
Oct 17, 2009 07:20 AM
mcbalagtas
Oct 31, 2008 07:25 AM
GMad
May 23, 2008 01:00 AM
ohskigod
Oct 23, 2006 11:15 PM
johnoswald
Jan 9, 2006 08:50 PM
