Strange little light problem
Old Feb 8, 2007 | 02:46 PM
daver80's Avatar
Default Strange little light problem
89 240DL wagon- When I turn on my headlights, the little bulb out light on the dash comes on. I've checked the bulbs, everything seems ok, usually just goes off after a minute or so. noticed today it stayed on until I put the turn signals on- went off. ? any ideas? dave
Old Feb 8, 2007 | 10:19 PM
Default RE: Strange little light problem
Are all the bulbs matching brands?
Maybe the sensor is bad.
Old Feb 9, 2007 | 02:03 PM
daver80's Avatar
The bulbs would be an easy enough thing to check, where it the sensor you speak of? I'll get right on it once it stops snowing... Dave
Old Feb 9, 2007 | 02:21 PM
volvo4mula's Avatar
The sensor is a red or black cylinder right under the instruments. Sometimes when they go bad the light on the dash starts coming on. Or the brake lights quit working.
It is also important on a 240 to make sure that all the bulbs match (all brass based or aluminum) and that the taillight connections are clean.
Old Feb 10, 2007 | 10:16 AM
Yes the sensor is un under the dash like right under the speedo cluster.
It is usually a red sensor.
Old Feb 12, 2007 | 07:24 PM
daver80's Avatar
Thanks for the input. I did see the Red sensor while doing the blower motor a few months ago. New, I bet they are a good chunk of chance, wicked cheap at a junkyard. any way to testone of these? Dave
Old Feb 12, 2007 | 09:46 PM
Open it up and inspect the solder joints really good.
Old Feb 13, 2007 | 03:29 AM
rene's Avatar
I have an 86 240 DL with the same warning light problem, including inoperable taillights. The volvo dealer provided great advice and a "bulb failure warning sensor" wiring diagram. He said there is a weak diode in the sensor and they used to change them with a stronger one from Radio Shack. How to test I don't know. I temporarily fixed the brake light problem by installing a jumper between power in (terminal # 54S with blue red wire) and power out to brake lights (terminals 54L and 54R with both being yellow wires). Now I have brake lights and a warning light. Other advice included simply cutting the sensor out and direct connecting all the wires. A new sensor was $129.00 Canadian dollars.
Rene
Moetheshmoe
Aug 10, 2015 07:34 PM
Benlocswiss
Jan 16, 2011 07:34 AM
keg22
Mar 13, 2010 06:03 AM
960 rookie
Oct 30, 2009 11:55 PM
njcardsfan
Apr 28, 2009 07:41 AM
