stupid tail lights
Old Jun 20, 2007 | 11:43 PM
pmr08's Avatar
Default stupid tail lights
so my 1990 vovlo 240 sedans passenger side tail light had a short at the brown wire at the connection to the circuit, and i went to a strip yard and got a new tail light circut and wire to replace the old, because the assembly looks good. then i replaced all the bulbs. when i use the brake now the upper lights inboth clusters(the ones normally off untill the brake is used) will not come on, and the outer left double fillament one on the drivers side clusterwill not work at all. no lights get brighter when the brake is pushed only the one in the back window comes on. i also replased the fuses by the drivers door at the same time as the bulbs but am thoroughly confused.
Old Jun 21, 2007 | 01:07 PM
blue goose's Avatar
Default RE: stupid tail lights
Make sure you have good ground connections to all lights. Re-seat the bulbs.
88740gle
Nov 13, 2015 08:13 AM
buellfire
Jun 20, 2009 12:37 AM
SpaceMomMort
Nov 6, 2008 02:02 AM
concongb
Nov 5, 2008 01:40 PM
marvb1
Mar 24, 2007 05:35 PM
