Sunroof is stuck open... HELP!
RE: Sunroof is stuck open... HELP!
The motor isn't hard to remove.
I'd suggest going to a pick and pull type place or a junk yard and getting another one. Mine's out too but fortunately it's stuck in the closed position ^^
Not sure if a crank would slide up in there or not. Perhaps worth a try, one less electrical part to fail.
There should be a manual way to shut it. Look in the owner's manual. We have a 940 that was stuck and had to use a screwdriver to manually turn a screw. This screw was hidden by a small plastic cover plate in the center ceiling just back of the windshield.
arifiano
06-07-2010 11:06 PM
Royalty
10-06-2007 08:53 AM
