SURGING when COLD
Old Feb 22, 2007 | 08:35 PM
Volvo240guy's Avatar
Default SURGING when COLD
I have cleaned th Throttle body and the Control valve and still have the problem. I have checked all the hoses and still have that problem. When I start the car the RPM shoot upand then drop to 900 or so But this happens when start the car it goes as high as 2000 then like 1500 then drops... Please help !!!!!!
Old Feb 22, 2007 | 09:20 PM
Default RE: SURGING when COLD
Is the check engine light on?
Old Feb 22, 2007 | 09:32 PM
No check engine light on at all
Old Feb 22, 2007 | 09:39 PM
I did check no light on at all
Old Feb 22, 2007 | 09:58 PM
Try pulling codes and see if any come up.
You might also want to try resetting the computer.
Old Feb 22, 2007 | 10:35 PM
I did check and their was a code 121 and reset discon the battery for about 15 min then sarted the car and checked no codes. Now I still have like a missing in the morning when it is cold out.
Old Feb 22, 2007 | 10:46 PM
Might be a small vaccum leak or a leaky injector.
Does it smell bad when cold?
Old Feb 23, 2007 | 08:42 AM
Hello I did check all the injectors and found that the one close to the firewall was lose so now what do I need to do to fix that ? And could that be the problem? Also could you give me a Idea on the way and steps to fix this ? It woudl be very helpful
Old Feb 24, 2007 | 12:10 PM
You need to replace the injector O-rings.[/align]There is 2 screws that hold the injector rail into the intake manifold.[/align]You should be able to just remove the 2 screws and pull the injector rail back far enough to get the injectors out to replace the o-rings.[/align][/align]When going back in with the injectors spray a little silicon or something like that on the o-rings before installing this way it won't tear the new o-ring.[/align]
vingus1977
Dec 17, 2013 10:50 PM
Dennis Bor
May 30, 2011 11:14 AM
arttu
Feb 15, 2007 10:16 PM
simonh9
Oct 9, 2005 02:17 PM
wmclott
Engine & Internal
Jun 4, 2005 04:55 PM
