swap gearbox B200K to B21A
Old Nov 12, 2005 | 09:02 AM
twoluckyone's Avatar
Default swap gearbox B200K to B21A
Hi,
I have a question about gearboxes.
Is it possible to use a 5speed gearbox of a Volvo 240 with B200K motor (1986) to replace the 4speed gearbox of my Volvo 240 with B21A engine (1976). Does the 5 speed gearbox fit to the B21A engine?
Another problem is that the 1986 gearbox has a electronic speedmeter and mine has a mechanical speedmeter with a cable. Is it possible to make a change at the 5speedgearbox sothat the mechanical speedmetercable fits to it?
Old Nov 12, 2005 | 10:03 AM
Default RE: swap gearbox B200K to B21A
It might bolt up.I think the bellhousings are pretty much all the same. The problem you will run into is maybe the drive shaft and the speedo. I don't think the 5 speed will have the gear to run the cable in the trans.
cs057
Oct 23, 2013 10:22 PM
hotwhlzs850
Aug 9, 2011 06:51 PM
bkcallahan
Jul 10, 2011 09:13 PM
mickys60t5
Aug 5, 2006 06:41 PM
Captain Zov
Mar 22, 2005 09:54 AM
