Swap for OEM Radiator
does anyoner know if there is a swap out for the OEM radiator on a 1991 740 turbo wagon. Mine is leaking and the pick and parts just pulled the 240 that was in the lot that i could have salvaged the RAD from. They have several S and V models but i have not gone to look at the fittings with 10 inches of snow on the ground.
740/940 up to 1991 uses a different radiator than 1992+ 7/9 (the 1992+ 740/940 radiator is larger)
me, I'd just get a new Nissen, its the exact fit, OE manufacturer, and NEW, any used radiator is likely just as old and prone to failing as the one you're replacing.
https://www.fcpeuro.com/products/vol...80-940-8603894
740Turbo_Temple (12-19-2020)
