Tail light problem
Old Oct 8, 2006 | 04:44 PM
oldvolvo's Avatar
Default Tail light problem
We're have a tail light issue with my daughter's 1989 240 DL. When the brakes are applied, the light at the lower right on the right side tail light assembly comes on, but very dim. When we turn on the headlights and step on the brake, the same light goes out completely. I've replaced the bulb and checked the contacts. Everything seems to be ok.
These are relatively new tail light assemblies. I replaced the stockers with new units (from ebay) about a year ago. Worked fine until recently.
Any ideas?
Old Oct 8, 2006 | 07:31 PM
billofdurham's Avatar
Default RE: Tail light problem
This is usually an indication of a bad earth (ground).
Old Oct 8, 2006 | 08:07 PM
oldvolvo's Avatar
ORIGINAL: billofdurham
Thanks. I'll check that. I haven't looked at the harness plug or the ground. Will do that right away!
88740gle
Nov 13, 2015 08:13 AM
buellfire
Jun 20, 2009 12:37 AM
arie
Jan 21, 2009 06:02 PM
jdbs3
Jan 5, 2009 07:35 PM
harebearva
Oct 18, 2008 11:11 PM
