In Tank Fuel pump question
Old Dec 17, 2017 | 12:02 PM
MrBric's Avatar
Default In Tank Fuel pump question
Should the in tank fuel pump run off of full battery voltage? or should it run off of less? I am only getting 10 volts to the in tank pump. This is also a brand new in tank pump.
Old Dec 18, 2017 | 09:34 AM
act1292's Avatar
Should be 12v to the pump. Make sure you are measuring to proper ground.
Old Dec 18, 2017 | 03:17 PM
also note quite a few aftermarket in-tank pumps are wired backwards :-/ so if you hook them up 'correctly', they suck instead of push.
also, see In the Tank - 240 Volvo Tank Pump and Sender for a very detailed discussion of 240 in tank pumps. 740/940 are quite similar except for the tank access port.
Jay Holland
Nov 15, 2015 02:47 PM
rphud
Sep 27, 2014 06:06 PM
spidersilva
Aug 17, 2011 07:23 PM
AnEskimo
Oct 7, 2010 07:28 AM
skyrider20
Nov 29, 2008 07:01 PM
