Installation of fuel pump in fuel tank
Old Oct 31, 2015 | 07:59 PM
Jay Holland's Avatar
Default Installation of fuel pump in fuel tank
1995 960 I am installing fuel pump tank assembly. I have a new seal. I am having a hard time getting this assembly into the tank.The seal wants to curl back on entry when pushed into the tank. I tried putting the seal in the tank first. The assembly will not push into the tank. Is there some kind of slippery stuff I could use to help this assembly slip into the tank. Thank you for your help.
Old Oct 31, 2015 | 08:09 PM
lev's Avatar
lev
Petroleum jelly, aka Vaseline. Put the seal on first, on the tank's opening, then push the assembly through--with the Vaseline on the surfaces all around.
Old Nov 15, 2015 | 02:47 PM
I got pump and sensor into the tank. Problem was the new seal was larger than old seal.
I ordered a second new seal and used super lube to install the pump finally was able to
push the part into the tank.
rphud
Sep 27, 2014 06:06 PM
KY740
May 15, 2011 10:43 AM
AnEskimo
Oct 7, 2010 07:28 AM
skyrider20
Nov 29, 2008 07:01 PM
pirate240
Aug 2, 2006 11:21 AM
