TEMPERATURE COMPENSATOR
Old Feb 4, 2006 | 06:45 AM
detrout's Avatar
Default TEMPERATURE COMPENSATOR
I have been having a problem with my temp gauge going up in the red. I have have the radiator checked and flushed. The head machined and checked for cracks and pretty much all the temp componets replaced to no avail. I just talked to a volvo parts dealer in wilmington and he told me that the guages very rarely go bad but rather the temp compensator. IS THIS TRUE NEW OWNER.
Old Feb 5, 2006 | 12:28 AM
Dingbat's Avatar
Default RE: TEMPERATURE COMPENSATOR
This link was given out by wojeepster in a previous post. I guess fixing this problem isn't hard.
http://www.ipdusa.com/ProductsCat.as...668&RootID=629
hope it helps
Old Feb 5, 2006 | 09:49 PM
wojeepster's Avatar
Once you get the gage cluster out take the screws out on the back the gages come out as a unit and you can unplug the temperature compensation board from there. You can buy IPD's kit or make your own from two computer jumpers with the backs cut off. Insert kinked jumper wire from the back and you are done. From then on your temperature gage will read actual temperature. When you go up a longgggg hill you will see the temperaure rise slightly and when you go down a longgg hill you will see the temp go down a little.
Old Feb 11, 2006 | 03:52 PM
Yes install the jumper wire from terminal 1 to 3 and you are done.
volvoandvw
Jun 13, 2007 03:28 AM
montysano
Mar 9, 2007 10:13 PM
markh3565
Dec 14, 2005 02:32 AM
markh3565
Dec 13, 2005 11:21 AM
brianjwagoner
Oct 29, 2005 02:57 PM
