terrible gas milage
Old Oct 31, 2007 | 02:24 AM
iamnickcarter's Avatar
Default terrible gas milage
My '76 242 DL
is getting around 10-15MPG.
This really sucks, I've got a K&N air filter, new plugs and wires, new dizzy cap and rotor, new fuel filter, new oil and filter, new flame trap, cleaned my fuel tank, replaced a few fuel lines...blahblahblah
I recently blocked off my charcoal canister. The thing is rediculous and I felt unnecessary so I blocked all the lines and removed it. I doubt that's the problem, honestly.
Right now my timing is set at 10* BTDC at 900RPMs.
Any ideas?
I think there's a fuel leak, who knows where. How do I spot one?
Old Oct 31, 2007 | 02:45 PM
funnyguy44444's Avatar
Default RE: terrible gas milage
It's eay to tell if you have a fuel leak just smell under the car after you park it. If you smell strong gas then you have a leak. If not you're good. Replacing the O2 sensor will get your millage up. also clean the throttle body.What kind of gas are you burning? If you live in a place where you can only get gasohol (the crap that is 10% ethanol) that decreases your millage but not by that much. Check your tires to make sure they are inflated properly and maybe add 2-3 pounds to increase millage. An oil change never hurts millage but it won't make a significant increase.
Dowst
Apr 5, 2013 11:02 AM
Kyle Clifford Metzger
Dec 1, 2012 07:12 PM
dman777
Jan 23, 2008 12:08 AM
shelbylay
Oct 28, 2007 11:48 PM
arejohn
Mar 29, 2007 01:53 PM
