Heat always "on"?
Old Oct 23, 2007 | 04:17 PM
Moon's Avatar
Default Heat always "on"?
The interior of my1983 240 is always hot, because I cannot turn off the heat!
Even if I slide the temperature control fully to the left, and turn the fan to the off position, I'm getting a slow but steady flow of hot air.
This is fine for Winter days, but not when the weather is hot because I can't get any cool air circulating.
Any thoughts?
Old Oct 23, 2007 | 09:52 PM
funnyguy44444's Avatar
Default RE: Heat always "on"?
The problem is the heater control valve. My '82 244 had the exact same problem. It is located just above and to the right of the drivers left foot behind the plastic pannel. It is kind of a pain in the *** to replace because you have to disconnect the heater hoses form the other side of the firewall so you don't flood the inside with antifreeze. Also there is some kind of weird thermostat device on there that I've never figured out what it's there for. It isn't too hard replace except for that weird thermostat thing.
Old Oct 24, 2007 | 08:41 AM
blue goose's Avatar
You may be able to adjust the cable to the control valve. When the valve is closed the cable should have about 1/8" of travel remaining.
Old Oct 24, 2007 | 05:30 PM
blue goose's Avatar
You can get access by removing the driver's side kick panel. Here are some pics from another site that may help clarify:
http://www.brickboard.com/RWD/index.htm?id=781119
Old Oct 30, 2007 | 04:40 PM
liljon2x07's Avatar
follow vehicle maker procedure for messing with the a/c and the heater pain in the *** i go to school for it many regulations that you have to follow
Old Oct 31, 2007 | 02:52 PM
Well if its just that the heat is always on then you shouldn't have to mess with the a/c at all. Yes there a lot of federal regulations bull **** you have to deal wiht with the a/c with these cars because they are r12 systems but the heater just works using antifreeze which as far as i know isn't regulated since you can buy it anywhere.
Henry Jones Junior
Mar 20, 2012 07:36 PM
mgimza
Nov 14, 2006 09:11 PM
AaronD81
Jun 2, 2006 08:39 PM
tennisguy
May 18, 2006 07:32 PM
barge
May 12, 2006 10:55 PM
