think this will work?
Old Jul 16, 2011 | 01:26 AM
dezertsub's Avatar
Default think this will work?
http://item.mobileweb.ebay.com/viewitem?itemId=300577456122&cmd=VIDESC&title=Desc ription&index=24&nav=SEARCH&nid=74151394975
Or should I just buy a cheap pep boys tach and not take the instrument panel apart? I just like to know what I'm turning, and really have no use for the clock...
(posted from my smartphone, not sure if the link will work for you)
Old Jul 16, 2011 | 02:33 PM
Burn Stains's Avatar
I don't think that instrument panel is all to difficult to remove, just remember where everything is connected. I think it would be easier than installing an aftermarket one because the connector is already behind the cluster. It seems a little high for me though. I have seen a kit with both a tach and a small clock go for about that much...
Old Jul 16, 2011 | 11:05 PM
Joseph/TX's Avatar
The instrument cluster on a 240 is easy to take out; I routinely pull them out at the wreck yard in less than 3 minutes. (if I see one with a trip meter showing anything other than all zeros there's a fair chance that the odometer gear has been replaced, have gotten several good ones this way) As Burn Stains pointed out, you're pre-wired for a tach; it's the red/white wire that isn't doing anything right now. Just did a transplant on my '89 and it was pretty much plug and play.
Old Jul 17, 2011 | 03:43 AM
dezertsub's Avatar
You guys rock, thanks. More eBay browsing revealed a tach-clock combo like Burn mentioned for less, just used that one as an example. Going to my local pick-a-part Tuesday, wish me luck!
Old Jul 17, 2011 | 07:07 PM
Yeah a yard is the way to go!
Old Jul 19, 2011 | 05:06 PM
dezertsub's Avatar
Very good day at the pick a part, got a complete instrument cluster for $30 that had a tach. Took mine out my old one, put tach in, and 25 minutes later I discovered that at 80mph, I'm turning 3K. Oh, and something that had been previously disconnected got reattached, and now I know how far I've gone!
Nic Graner
Jan 5, 2013 10:39 PM
99VolvoV70
Sep 26, 2007 09:02 AM
Gonzo
Jun 29, 2005 08:09 PM
Erock198
Oct 28, 2003 02:28 PM
Big Daddy
Oct 24, 2003 09:46 PM
