Timing belt/Interference Motor
Old Mar 20, 2013 | 02:38 PM
SLeeHobbs's Avatar
Unhappy Timing belt/Interference Motor
My timing belt snapped on my 1990 B230f engine. My mechanic advises that engine is now toast and requires head/valve replacement. He indicates that 95 % of all engines of this type are terminally damaged when this trauma occurs. Advice from the those who know. Help!
Old Mar 20, 2013 | 03:31 PM
find a new mechanic. this one knows nothing of volvos.
the only 'interference' engine in the redblock lineup is the B234F DOHC 16V. ALL the rest are completely non-interference, and you just need a new timing belt (and tensioner, and probably should replace the engine seals if they haven't been done in awhile, ditto the water pump, as its all exposed when you're doing the timing belt).
Old Mar 20, 2013 | 07:01 PM
urbino's Avatar
Pierce, this board is fortunate to have you in residence...
Old Mar 20, 2013 | 09:13 PM
SLeeHobbs's Avatar
Pierce, Ditto on the praise. I appreciate your quick response and keen knowledge. The car is used by my daughter and she was crushed that it might be a gonner (I as well). This is my eleventh Volvo and I shan't give it up! I would install parts myself but I'm w/out my tools!
Old Mar 20, 2013 | 11:20 PM
brickrunner's Avatar
I would consider changing the timing belt tensioner as well. FYI the timing belt has to be installed with the marks lining up exactly, if they are off by just one tooth the engine will not run.
Old Mar 21, 2013 | 11:55 AM
98T5's Avatar
Thanks Pierce! I just bought a 93' 940 and I shutter to think the belt snapping on me actually would kill the car. that's just insane!!!
fiey24
May 27, 2019 12:59 PM
pznuttz
Sep 4, 2015 11:22 PM
mgbbob
Mar 28, 2012 01:58 PM
dads 740 turbo
Oct 13, 2008 03:54 PM
KINGI5T850
Apr 4, 2006 11:45 PM
