timing belt slips off tensioner B230 engine
Old Nov 10, 2008 | 09:15 PM
  #21
fredbyte's Avatar
Default RE: timing belt slips off tensioner B230 engine
Finally gave up. Couldn't figure out alignment angles. Just used old tensioner roller. That works. Put everything back together and it runs.
Old Nov 10, 2008 | 09:19 PM
  #22
OK sorry it was messing up like that maybe just bad part.
Old Nov 27, 2013 | 12:08 PM
  #23
FredDC's Avatar
I have the same problem. I have bent two idler brackets. As the center bolt holds the wheel snug to the block the bent bracket is esp. odd - twice.
Old Nov 27, 2013 | 12:16 PM
  #24
are these idle brackets volvo brand, or 3rd party ?
Old Nov 28, 2013 | 11:37 AM
  #25
lev's Avatar
lev
Why don't you start a new thread describing what's going on? History, etc?
Old Mar 30, 2015 | 05:25 PM
  #26
Jeffrey Quam's Avatar
Default Jeffrey Quam JAQ'S Garage
We had the same thing happen--the timing belt would immediately work itself to the outer edge of the cogged pulleys and would have come off I think if the crank hub was not there to stop it. We don't know the history except that the car came to us not running and supposedly the belt had broken. We replaced the exhaust cam hydraulic pulley, which leaked anyway, all the tensioners and water pump with no improvement. We finally had our machinist tech use a threaded hole in the block under the triangular idler to install a stub threaded stud with a slot in it so he could adjust the angle of that idler and he got the belt to run true--something about that idler I think was faulty--and not just the one we put in. The one that was on the car when we got it did the same thing too. It seems there are some weird idlers out there.
jbpaulson
Nov 27, 2013 12:18 PM
arekaye
Mar 26, 2013 04:45 PM
Rich Ard
Nov 1, 2010 04:02 PM
dads 740 turbo
Nov 6, 2008 07:50 AM
whyflygti
Sep 30, 2005 09:11 PM
