Tires for low yearly mileage car
Old Oct 8, 2010 | 10:57 AM
jdbs3's Avatar
Default Tires for low yearly mileage car
1990 240DL sedan, 150k miles
Standard tire sizes 185 70 R14. I'm happy with this. BUT I only drive the car 6K miles per year. Looked at this forum and tire rack. The Yokohama and Pirelli each had mixed reviews. The Micheline Harmony stood out, but at a cost of $89 plus shipping it's an expensive choice.
And given my yearly mileage, the tires will dry rot before the tread wears out. This is exactly what happened to the Micheline that came new with the (used) car and now need replacement after 6 years.
What other recommendations would folks make for a less expensive tire that gets good (but not mixed) reviews??
thanks
Old Oct 8, 2010 | 10:12 PM
swiftjustice44's Avatar
Depends a lot on where you live. Here in Texas, after 2 summers, tires are iffy for road trips. My solution, except for my V8, is to buy inexpensive tires. Tire Rack (only place I use) has Sumitomo HTR T4's for your size for $52 each. It's a darn good tire, tread depth isn't quite as deep as some but a good tire. If you really want to broaden your tire selection, ditch those 14" steelies and get a set of 15's. 14's are rapidly going the way of the 13. In 15's, the Fuzion HRi in 205/60/15 is an awesome tire for $55...and a darn good snow tire in a pinch too!!
Old Oct 15, 2010 | 10:13 AM
jdbs3's Avatar
Default Tire sizes I can use
I'm in New England.
I was just looking at the standard size 185 70 R14, but now beginning to look at other sizes.
What other sizes will fit on the 14" rims? For example, will a 195/60-15 go on this rim, or others?
Old Oct 15, 2010 | 04:39 PM
bigdaddyrdpjr's Avatar
Wink
Originally Posted by jdbs3
I'm in New England.
Uhhhh no. 195/60-15 is a 15 inch tire. Unless you get 15" wheels as suggested above u have to stick with wheel sizes the end in 14.
The fuzion hri is ok, I have had them on a 300zx.
Put your car info in on tirerack.com and see what they give you.
Old Oct 15, 2010 | 08:27 PM
use the following link to see what different width tires will work without messing up the speedometer accuracy...14" tires are getting tough to find in any sort of selection though...
http://www.miata.net/garage/tirecalc.html
Old Jul 29, 2012 | 10:33 PM
mlaren's Avatar
Default tire size
Hi Volvo fans
someone gave me 4 Michelin 215/70/R15's. I have a 1990 volvo 240dl sedan with th 15" crisscross alum rims...will these tires fit or will they rub...?
Old Jul 31, 2012 | 08:14 PM
eljefino's Avatar
hankook 727s are pretty cheap and I had a set I liked.
Tires oxidize because there's an expensive preservative that they cheap out on when they "bake" a tire. A cheaper tire runs the risk of them using even less of that preservative.
Will you be driving in the snow on these?
white83glt
Jan 20, 2012 11:42 AM
moondust
Apr 2, 2011 05:40 PM
reedfriendly
Nov 4, 2010 06:38 PM
elderzap
Nov 7, 2007 04:58 PM
gr8gatzby
Aug 10, 2005 03:28 PM
