TPS Question 94 940
I can not seem to find the answer to this question. When the throttle plate is closed should I have continuity between outside pin and center on the TPS? I am thinking it is a closed circuit during idle .. hence, there should be continuity ... is this correct??
Maybe this can help you: http://www.volvowiringdiagrams.com/v...940%201994.pdf
On page 14-15 is the ECU and related outputs. page 15 has the TPs.
turbo model is pages 18-19
the idle switch on the TPS should be closed (continuity) at idle, and open as soon as you move the throttle off idle.
the full throttle switch (if your model is so equipped) closes when the throttle is nearly floored and tells the ECU to go full out.
