Fpr and tps question
Old Mar 24, 2012 | 07:17 AM
volvoguy23's Avatar
Default Fpr and tps question
I have a tps code (faulty signal I believe) and the car does have a rough idle but can a tps slowly get worse or do they just quit working? I've read that they can get out of adjustment some how..but how? I just ordered an oem tps so if that doesn't fix the problem I'm leaning towards the fpr... Car seems to be running rich and can smell gas when getting out of the car and mpg is averaged at 20.
Old Mar 24, 2012 | 08:15 AM
Turkey_Sandwich's Avatar
There is no adjustment on the 850 TPS. The TPS is just an electrical device that produces a variable resistance based on throttle blade angle, it can go bad in any fashion.
Old Mar 24, 2012 | 09:39 AM
Think of the TPS as an older dimmer switch like on the mid 70-80's cars.
You could turn it to adjust the dash lights and sometimes you hit spots where they go off instead of adjusting then come back on. Same basic design.
laxman1100
Apr 28, 2011 11:15 AM
mountaineer
Feb 4, 2009 04:56 PM
rupert77
Jan 25, 2009 05:18 PM
Forsyth
Sep 1, 2008 01:31 PM
bkraff18
Jun 24, 2008 08:45 AM
