Tranny fluid change
Old Feb 28, 2007 | 10:38 AM
daver80's Avatar
Default Tranny fluid change
89' 240 automatic, on a transmission fluid change, do people usually drop the whole pan and change the tranny filter, gasket and all that. No drain plug, right? Only owned it since Sept, dont really know it's (transmission) history. Dave
Old Feb 28, 2007 | 09:55 PM
Default RE: Tranny fluid change
Remove the drain plug it should drop about 3 quarts.
Old Mar 1, 2007 | 03:09 PM
daver80's Avatar
Thanks Tech! It looks like the tranny holds about 7 quarts or so, is there any way to get more of that old stuff out? Seems like a drain plug would drain as much as dropping the pan. Dave
Old Mar 1, 2007 | 10:14 PM
If you wanted to get more out you could remove the return line from the radiator and start it up and drain some out then install 2 quarts and start again till it is all clean.
Use a clear hose and when you see bubbles coming out of the hose shut it off.
Usually about 2 quarts.
Old Mar 2, 2007 | 01:22 PM
daver80's Avatar
Thanks tech- I'll try it this weekend. D
greggw2gs
Apr 8, 2009 02:53 PM
02s60
Aug 27, 2008 05:29 AM
Billc
Jul 23, 2008 11:36 AM
phxvolvo
Feb 24, 2007 10:50 AM
sebren
Apr 6, 2006 11:27 AM
