Trans fluid change??
Old Jan 22, 2008 | 06:58 AM
gforce's Avatar
Default Trans fluid change??
1991 740 non turbo. I do not know how long ago, if ever, trans fluid and filter have been changed. Car has 316k on it, fluid is more of a brown color then red. Trans is shifting fine. Should I change fluid and filter???? or leave it alone and pray! Thec if you read this I hope you are sitting down----- I have learned from reading your post you are THE SCHEDULED MAINT MAN.
Thanks for any imput or advice.
Old Jan 22, 2008 | 10:46 AM
blue goose's Avatar
Default RE: Trans fluid change??
I'm not Thec, but I would change the tranny fluid using the coolant line from the rad. I would not touch the pan or the filter. Scheduled maintenance is 30k miles I think.
Old Jan 22, 2008 | 11:32 AM
gforce's Avatar
Thank you Blue Goose--- I was worried about dropping the pan. Book tells me dextron II, is it still available?
Old Jan 22, 2008 | 04:48 PM
blue goose's Avatar
Use Dexron III is fine. Or Dexron/Mercon.
ldsafety
Jun 11, 2008 05:51 PM
nandrolone
Jan 10, 2008 08:29 PM
yankees1
Oct 24, 2006 02:02 PM
novablue69
Dec 26, 2005 11:52 AM
novablue69
Dec 24, 2005 02:53 PM
