transmission codes '93 940??
Old Oct 23, 2008 | 11:42 AM
k's Avatar
k
Default transmission codes '93 940??
Hi all,
We have a '93 940 wagon, and the automatic transmission is starting to behave less than optimally...
When the car has been cold (first run of the day) and more often now that it is getting colder, it will shift up from 1 to 2 fine, but then it will get stuck in 2nd for a while, it doesn't want to go into 3r for a while...sometimes letting off the gas just slightly will make it 'get settled in'. I put a bit of lube on the kick down cable (but not really a thorough job, didn't want to get involved in removal and all), which seemed to help a bit, but I 'd like to track down the problem and fix it good.
Searching around on here I read that the OBD on a 960 (95/96?) has a mode for checking codes related to the transmission...does that exist on the 940? I know that in the OBD port 2 is for ignition & port 6 for fuel- what are all of the other OBD ports for?
Thanks!
K
Old Oct 23, 2008 | 12:39 PM
billofdurham's Avatar
Default RE: transmission codes '93 940??
The ability to read transmission codes is limited to the AW40 range of gearboxes on the 960 and S/V90.
How long is it since the transmission was flushed andthe fluid replaced?
Old Oct 23, 2008 | 01:21 PM
k's Avatar
k
Transmission was serviced back in April...not sure they did a full flush though...gotta check back through the records
before that in 2007 the car got new fluids
AW71L transmission box
jeffrisley
Jun 14, 2015 01:48 PM
gabyman97596
May 14, 2007 09:52 PM
dwhartwell
Mar 25, 2007 03:33 PM
cranky
Aug 5, 2005 09:46 PM
