Tune-up FAIL
Old Dec 19, 2011 | 01:17 PM
ajvogt89's Avatar
Default Tune-up FAIL
Howdy,
So I went ahead an bought an IPD extended tune-up kit for my 91 740 no-turbo. Last night I replaced the spark plugs (having adjusted the gap to 0.030"), replaced the cap and rotor and the spark plug wires. Went to fire it up and I have never heard a more miserable engine... I am wondering where I went wrong... Having replaced the rotor, I assumed there was only one direction the rotor could face due to the slotted fit. With regards to the wires, I used intuition and the shortest wire went to the closest plug and leftmost plug end on the distributor (if you are facing the car).
My initial guess was that the wires were not making complete contact with the head of the spark plug but I guess this is how wires fit? It seemed real loose to me...
Anywho, any help would kindly be appreciated. Thanks!
Old Dec 19, 2011 | 01:47 PM
jagtoes's Avatar
Originally Posted by ajvogt89
Howdy,
How did it run before you touched it. If OK then you most likely have some wires on the wrong cylinder. Do we assume you matched the wires to the correct location on the cap. If you look at the cap you will see the cylinder number each one goes to. Recheck that and see if they are right.
Old Dec 19, 2011 | 02:28 PM
ajvogt89's Avatar
The car ran perfectly... Somebody else was telling me I could have messed up the timing by means of the distributor... Anyone agree?
Old Dec 19, 2011 | 02:29 PM
ajvogt89's Avatar
I will check on the distributor cap to make sure the right wire went to the right cylinder, but I'm pretty sure I had gotten that right.
Old Dec 19, 2011 | 03:07 PM
bubba240's Avatar
Some plug wire sets require that you remove/unscrew the top posts of the spark plugs. That was the case with some autolite wires I used with Bosch plugs.
Old Dec 19, 2011 | 04:50 PM
jagtoes's Avatar
The dizzy is only there to distribute the spark. The timing is done by the ECU so I doubt you messed up the timing. You need to go back and review everything that you did. Somewhere you screwed up so walk back through the process. you'll find the problem.
Old Dec 20, 2011 | 08:38 AM
ajvogt89's Avatar
You were right, miss-matched a wire, car runs... ok.
southernoregondefense
Jun 29, 2011 05:45 PM
colgate41
Jan 16, 2008 02:00 PM
tthrivi
Aug 11, 2007 10:07 AM
ALJOSEPH
Sep 6, 2006 07:01 PM
vvvolvo
Sep 4, 2005 01:27 AM
