Turbo Conversion
Old Mar 8, 2009 | 08:48 AM
303240DL's Avatar
Default Turbo Conversion
hi i em new to this site. i currently own a 1987 240DL with a B230F engine i have researched a little about my car and found that 1 of the models of the same year has the same engine as mine but it is turbo (B230FT) i read that the B230F has a 9:8:1 compression which i em lead to understand thats safe enough to boost on.... my question is what all would i need to turbo my car W/O swaping the whole engine..i have seen other 200 series of the same year running B230FT's....
i have listed i would need to swap the following parts
( turbo,down pipe,exhaust manifold,ecu,fuel injectors)
and i would need to get a BOV,Wastegate,and intercooler.
is there anything else i should know about swaping the turbo onto my engine
i know 1 of the oil feeds needs to be taped from the oil pan but i dont know where the other 1 needs to go......maybe the valve cover?
any help would be greatly appriciated thanks.
Old Mar 8, 2009 | 09:46 AM
S70driver's Avatar
You wouldn't need a BOV unless you just wanted it for the sound.
- Intercooler hard pipes
- Intercooler hoses
- Vacuum lines
- Oil or water lines for the turbo
Have your ECU tuned for the turbo, don't just get a turbo ECU and use it that way. This is probably the most important part to have your car tuned properly.
You will need a boost gauge to make sure your boosting properly. You'll probably want a WIDEBAND A/F gauge. Do not buy a NARROWBAND A/F gauge. Widebands actually tell you your A/F ratio while a Narrowband just has pretty lights that flash and don't tell you a thing about your A/F ratios. yes the price difference is significant, but if you want a reliable machine you'll want the best and you want to know what the real A/F ratio is.
zpmada
May 15, 2009 12:28 AM
kgolsan
Dec 8, 2008 03:11 PM
i5turbo
May 21, 2007 09:44 PM
MattB850in
Apr 10, 2007 07:55 PM
DJboozeAlot
Nov 13, 2006 06:19 PM
