two issues on engine problems
Old Jul 6, 2012 | 11:03 PM
Beardog's Avatar
Default two issues on engine problems
Allright guys,
my 89 745 gl wagon with b230f is having some fuel engine issues which may be related or unrelated.
the first issues is the engine starts like its being flooded a bit so it stutters and burbles, and then after a minute or so, the sensors all kick in and the engine smooths out.
The other issue is that there is a vibration in the engine at 2500 rpm. I can replicate under acceleration and at speed, I can also replicate it at a standstill in neutral, so engine issue.
What are your thoughts on the issue?
My thought is a leaking/bad fuel injector or maybe the cold start injector for the start up issue.
Old Jul 7, 2012 | 12:36 AM
hvolvo's Avatar
The vibration might be a bad motor/ tranny mount or your transmission change the tranny fluid.check your vbelts ,fuel filter get a Manuel
Old Jul 15, 2012 | 07:46 PM
bitter356's Avatar
Default B230f
First; State of tune, clean mass air flow meter and connector. B230F's have a common carbon deposit issues on intake valves,BP has an intake carbon kit to remove it. Check your coolant temp sensor for the FI and not the gauge. On the vibration issue, after the mounts check out try a transmission filter/fluid change. You might have a torque converter stator locking up, transmission service might take care of this. My 87 wagon had similar vibration problems until I replaced the converter.
Old Jul 16, 2012 | 01:44 AM
91-740Turbo's Avatar
Your vibration, to me, sounds like a cylinder is skipping.
Old Aug 31, 2012 | 05:10 AM
Beardog's Avatar
Guys I fixed this cold start problem by replacing the fuerl injectors with cleaned remanufactured injectors. There is still the smallest noticeable rumble in the engine which quickly goes away, but I'm being picky.
Old Aug 31, 2012 | 05:15 AM
Beardog's Avatar
Default Throwing an OBD code while idling
Guys, I'm ready to try and replace the O2 sensor, But wanted some opinions first before I crawl under there. My car idles fine, but it will throw a 212 code "Signal missing/faulty from oxygen sensor" when it does a long idle like when I'm loading up the car with the engine running. Any ideas as to why?
Schaeffy
Aug 15, 2012 11:04 PM
jbuck
Nov 16, 2011 05:48 PM
gatorbrit
Jan 29, 2009 12:04 PM
v70 2.4t
Jun 12, 2006 03:59 AM
