Two Weber 40's enough fuel for a cam?
Old Feb 27, 2024 | 11:36 AM
jonikopsuka's Avatar
Question Two Weber 40's enough fuel for a cam?
On next Tuesday I going over to pick up two (used) Weber 40 DCOE carbs because my original Solex Cisac is shot out and doesn't keep in tune.
I was wondering if those two 40's are enough if I want to get a bigger cam in the near future. A Finnish tuning shop within mail order distance of me sells two types of decent looking cams they make in house with one being slightly tamer than a GT6 and the other being a bit above in terms of lift.
This question popped into my mind because while looking at the GT6 cam a lot of people seem to be recommending at least 2x 45 DCOE if not bigger.
The car in question is a 1984 242 with a B19K engine that's (mostly) stock.
The Carbs I'm omw to get come with the following jets according to the seller and I am aware that I'll most likely need to change some of these:
Idle 55f17
air 170
mix f16
pump 35
start 65f5
40mm chokes
I will appreciate your insight.
Old Feb 27, 2024 | 01:13 PM
sure twin DCOEs should be good enough for a cam and can get you to the 150 hp range for a 2L 4 cylinder.
trandung123
Sep 16, 2014 05:22 AM
trandung123
Sep 15, 2014 08:47 AM
none4me
Sep 2, 2010 09:28 AM
tturnpaw
Apr 22, 2010 07:08 PM
89240spkwa
Feb 26, 2009 12:31 PM
