U Joint Going Out On My 740GL!!
Old Aug 7, 2010 | 11:28 AM
MNWILD's Avatar
Default U Joint Going Out On My 740GL!!
Hello everyone, I know that the u joint is cheap. What do you think it will cost to have a new one put in?
Thanks,
Scott
Old Aug 7, 2010 | 05:55 PM
swiftjustice44's Avatar
Well Scott, there are three u joints. while it isn't etched in granite to replace all 3 at the same time the fact is while the drive shaft is pulled one generally does. Particularly, as you know, the parts are not particularly expensive. As well, this is the time to check the pinion seal, carrier bearing and carrier bearing support. Two hours labor should get it all.
Old Aug 7, 2010 | 11:14 PM
MNWILD's Avatar
Thank you for responding back! I really appreciate it!
Old Aug 11, 2010 | 12:39 PM
wojeepster's Avatar
Make sure it is the u joints. Every volvo I have checked with klunk in forward, klunk when put in reverse it was the two large rubber rear end bushings all clapped out.
dpvovo
Feb 18, 2019 07:41 PM
dobrosailor
Jan 16, 2010 10:21 PM
dobrosailor
Jan 12, 2010 06:20 AM
daver80
Jun 29, 2009 03:01 PM
XSive
Jun 20, 2007 05:15 PM
