Urgent help!! Gota go today
Old Aug 29, 2012 | 11:05 AM
bummy's Avatar
Exclamation Urgent help!! Gota go today
Wheel keeps vibrating loose. lug nuts unwind them selfs. dust cap feels hot. Just had the bearing replaced. oh this is the front tire BTW. SCARY ****. I gota take it today though, about 40 miles. If it start to wobble Ill just tighten em back up. I guess.
Old Aug 30, 2012 | 01:45 AM
Titan Joe's Avatar
Take the wheel off and check the threads on the studs and nuts. Replace if stripped. Also, try using a torque wrench to tighten, that way you know that they are tight enough, but not overly so. I can't remember the spec, but it might be in the owner's manual.
Old Aug 30, 2012 | 02:03 AM
brickrunner's Avatar
On the 940 the torque value is 62 or 65 ft. lbs. I am sure that it is the same with the 740 as well as the 240. It is listed on the wheel bearing dust caps.
Old Aug 30, 2012 | 05:53 AM
act1292's Avatar
Make sure the nuts are on with the flat side out. The conical side goes towards the rim. If installed backwards, the wheel will wobble and work the nuts loose
Old Aug 30, 2012 | 10:25 AM
bummy's Avatar
Well I made it! Sweating through my shirt the whole way. Had to re tighten once I started to feel it.
No, there not striped. They tighten down pretty good. The aftermarket rims are aluminum and I noticed the lugs dug holes into them maybe 1/8" 1/4" or so.
Yes I made sure. I could have easily made that mistake though.
Man I gotta drive this thing again today SHEEESH! :/
Old Aug 31, 2012 | 07:01 AM
act1292's Avatar
Could it be that the holes in the rim have worn out of round along with the lug nuts? One way to test this is to swap the rim & nuts to the other side. If the problem follows it, then replace the rim and nuts.
Old Aug 31, 2012 | 01:33 PM
Are your rims stock, or are they aftermarket or from another Volvo?
Old Aug 31, 2012 | 04:03 PM
bummy's Avatar
I did rotate them. No change same side comes loose.
No there after market with the same lug pattern.
Old Aug 31, 2012 | 07:33 PM
Wicksvolvo's Avatar
I'd change the hub/nuts. Start over with something new or from salvage yard. I've heard of loose nuts causing damage to the bearing, so I'd check that bearing you just replaced. Just a thought
Old Sep 1, 2012 | 07:22 AM
bummy's Avatar
Hi, What am I checking for? metal shavings or?
Old Sep 2, 2012 | 07:44 AM
jagtoes's Avatar
Go buy a new set of lugs made for aluminum wheels. Also check the center hole to make sure it fits correctly. If the wheel is not flat on the hub or if the center hole is to big then the wheel will come loose.
Old Sep 3, 2012 | 12:10 PM
bummy's Avatar
Napa didn't have them and acted like I didnt know what I was talking about. They said aluminum lug nuts? then looked at me like I was crazy
Old Sep 3, 2012 | 12:42 PM
zloetakoe's Avatar
I don't think he was suggesting buying "aluminum lug nuts". Just lug nuts that are meant for aluminum rims.
2 cents.
Old Sep 3, 2012 | 06:18 PM
jagtoes's Avatar
Go to someplace like autozone and bring one of your lug nuts with you. Tell the sales person you want a set of lug nuts with either a conical or round seat. They usually come in sets of 5. Also as I mentioned check the rim to make sure it fits on the hub and there is no slop. Volvo wheels are hub centric and should have a fairly tight fit on the center of the hub.
All lugs are usually made of steel.
robingichuhi
Feb 22, 2017 04:34 PM
BPATR1CK
Sep 13, 2011 12:25 PM
DecalService
Nov 19, 2008 08:05 PM
mikeheraly
May 28, 2008 04:38 PM
92Typhoon
Nov 6, 2007 02:22 PM
