Urgent help w/ heater issue...HELP
Old Sep 12, 2011 | 02:35 PM
BPATR1CK's Avatar
Default Urgent help w/ heater issue...HELP
Just changed upper, lower, and degas bottle hoses. Car is a 98 v70 t5. After filling with coolant and running to operating temp with controls to full heat, heater will only blow hot on drivers side vents.
Have a vacuum hose leading nowhere, one that comes off the 12v box clipped to line back of the airbox. (yellow stripe on black rubber line I believe...
Any thoughts from you guys on this?
EDIT: HEATER ISSUE HAS BEEN RESOLVED. THANKS FOR YOUR VIEWS! However, the airbox and battery tray removal on this car were "interesting." Hose is still hanging, car is running great for now...
P.S. What have you guys used to relieve the serpentine/drive belt tension? THIS IS NOW MY MAIN INQUIRY!!
Thanks in advance.
Old Sep 12, 2011 | 04:57 PM
Step 6 here to remove serpentine belt: Timing belt replacement instructions on a 1997 Volvo 960
You can view most timing belt instructions to see serpentine removal instructions.
Old Sep 13, 2011 | 12:25 PM
BPATR1CK's Avatar
Thanks for taking the time to post the link; I appreciate it...Couldnt quite make sense of the serpentine/ drive belt tensioner relief tool...
Just need to know what to stick in the hole to allow me to rotate the tensioner. Its driving me bananas! Thanks again for your time.
robingichuhi
Feb 22, 2017 04:34 PM
ycartf
May 6, 2013 11:19 AM
jmallie
Oct 3, 2009 09:43 PM
Chupa517
Apr 2, 2009 11:14 AM
keithscianna
Dec 20, 2008 03:26 AM
