URGENT! Removing rear hatch Volco 240 1990 wagon
Old Sep 30, 2016 | 01:17 PM
itsmesunny's Avatar
Default URGENT! Removing rear hatch Volco 240 1990 wagon
Someone is here NOW to work on fixing the electrical on the hatch,
to fix the 3rd brake light that does not work.
Can the hatch be removed and put back on?
It appears that the electrical wires go thru the hatch - ? - and to get to them the
hatch needs to be removed.
Old Sep 30, 2016 | 01:45 PM
Nichals's Avatar
Sure
Remove the headliner and you will see 2 bolts on each hinge
The wires go through the hinges on sides but the passenger side also has the ground wire
The hinges are also attached to the door with 2 bolts
One on the hinge arm and one that goes into an L shaped bracket.
If you google an image of the hinge all will be clear
Old Sep 30, 2016 | 01:52 PM
itsmesunny's Avatar
What is the headliner?
Old Sep 30, 2016 | 02:08 PM
Nichals's Avatar
Basically, it's the fabric covering the "roof" of the car
Sit in the car and look up, that's the headliner.
Old Sep 30, 2016 | 02:14 PM
itsmesunny's Avatar
Yeah, it was already off. Silly question.
Old Sep 30, 2016 | 02:17 PM
itsmesunny's Avatar
Default It's done. Thank you!
Thanks for the replies.
They were timely.
Old Sep 30, 2016 | 03:41 PM
Nichals's Avatar
Sure thing, I am glad to help!
Also, If you need to replace the hinge with the ground strap in it, be aware that the wire is broken on almost ALL used hinges
I made a new one out of flexible wire and layers of shrink tubing, then riveted it in.
hsinchu
Mar 11, 2011 11:32 PM
First time Volvo Owner
Dec 8, 2010 10:52 PM
tuco23
Dec 15, 2008 03:40 PM
hockey2
Mar 12, 2008 09:57 AM
940turbo94
Nov 29, 2007 09:39 PM
