Urgent Tech Help!! light Troubles
Old Dec 18, 2008 | 01:08 PM
sgtatarms003's Avatar
Default Urgent Tech Help!! light Troubles
i have a 1989 volvo 240 gl when i turn the lights on they come on. when i hit the brakes only the third light comes on when the running lights are on. if they are off all three come on like there supposed to. if i put it in reverse no back up lights. when i turn lights on it shows a bulb blown but all bulbs and fuses are fine. please help me figure this out.
Thanks
Philip Venero N.Florida
Old Dec 18, 2008 | 04:23 PM
Default RE: Urgent Tech Help!! light Troubles
Sounds like Ground wire isn't grounding or a socket is bad.
Old Dec 18, 2008 | 10:04 PM
obaloney's Avatar
I'd recommend pulling the taillight assemblies (held in by a couple of nuts). Check the grounds on both sides, all the connectors to the bulbs, and the bulb housings and sockets. Get some de-ox gel and put some on every connection, including the grounds. Wouldn't hurt to replace the bulbs also. I go thought this ritual every year to prevent problems.
Old Dec 19, 2008 | 07:28 AM
Also forgot to mention in my original post to make sure the R/S tail light has a white socket for the brake/parking light bulb position.
robingichuhi
Feb 22, 2017 04:34 PM
volvo740wa2
Aug 31, 2015 07:08 PM
Dan01501
Dec 28, 2008 10:39 PM
klodge
Dec 15, 2008 02:49 PM
dragonz
Nov 9, 2008 08:23 PM
