Use an '89 fuel pressure regulator on my '88 240?
Old Jul 28, 2017 | 08:56 PM
onetwothreetim's Avatar
Default Use an '89 fuel pressure regulator on my '88 240?
Hello,
I'm having multiple starting problems with my '88 Volvo 240 and I was wondering if someone might be able to help me out by answering a question or two about the fuel pressure regulator which seems to be specific to the 1988 model year? Mine leaks gas from the vacuum line so I guess it needs replaced.
I have several problems with the car. It's been sitting for quite a while and I don't want to sink a lot of money into it prematurely.
I've found very inexpensive fuel pressure regulators on ebay for the '89 (and up) model years, only $13.00. My my year ('88) ranges anywhere from $65.00 to $165.00.
From the pictures it's obvious that the parts are physically interchangeable, but from what I've found through searching is that the '89 regulator must have a higher pressure (44 psi or 3 bar?)
My two questions are these:
1.) (most important to me) Can I use the 1989 pressure regulator in my '88 Volvo 240 without causing damage?
2.) What is the operating pressure of my '88 fuel injection system?
My question is the exact opposite of the one asked on the forum which can be found here:
Fuel Pressure Regulator 240 -- Will 88 work on 89?
https://volvoforums.com/forum/volvo-...rk-89-a-45138/
Thank you in advance for any replies. I greatly appreciate it.
Regards,
Tim
Old Jul 30, 2017 | 11:08 PM
240's from around 1985 up to 1988 are LH 2.2, and use a Chrysler ignition system. 1989+ are LH 2.4.
LH 2.2 uses lower (2.5 bar?) fuel pressure. the 3 bar regulator will NOT work.
Old Aug 2, 2017 | 08:23 AM
Thank you for the information. I had no idea that Volvo used a Chrysler injection system. Does anyone know of a chart or just a plain old listing of the fuel pressures for the different years of Volvo 240's? I can't seem to find that anywhere. It seems like this would be useful knowledge for anyone doing any kind of a fuel system swap.
I've ordered a regulator. Still hasn't come yet.
Thanks again.
Tim
Old Aug 2, 2017 | 11:18 AM
there's a ton of data on this site, all organized by category...
https://www.volvoclub.org.uk/faq/FAQSummary1.html
MntnDewMan
Apr 3, 2024 04:05 PM
PMOURASSA
Sep 9, 2015 10:15 AM
hvolvo
Jul 15, 2012 02:17 PM
slsnumber1
Mar 15, 2011 02:55 PM
AnEskimo
Sep 5, 2010 03:45 AM
