Vacuum specs
Old Jan 16, 2020 | 06:48 PM
Syndave's Avatar
Default Vacuum specs
Hello,
A mechanic friend did a compression/vacuum test on my car and found that its at 15 and said most vehicles are usually at 25. Is this due to a vacuum leak or is this normal?
Old Jan 16, 2020 | 08:02 PM
cylinder compression tests usually are in the 150-200 PSI range, which is 10-14 BAR. cause of low cylinder compression is either worn rings or valves.
Old Jan 17, 2020 | 12:20 PM
Syndave's Avatar
Thank you
royalslover
May 14, 2014 08:43 PM
lilredcamaros
May 8, 2013 05:28 AM
Da Tow'd
Penta
Jul 26, 2012 09:32 PM
gilber33
Aug 8, 2009 09:50 AM
melymel
Oct 6, 2007 08:53 AM
