Values for B23A coolant temp sensor?
Old Sep 12, 2019 | 06:52 AM
rmmc's Avatar
Default Values for B23A coolant temp sensor?
I suspect it's not working right, at 15 ºC/60 ºF it's 1.10 ohm at 100 ºC/212 ºF it read 0.10 ohm. Does this indicate a defective unit?
Old Sep 12, 2019 | 07:41 AM
as a general guide, temp sensors should be ~3000 ohms at room temp (even higher at colder ambient temps) and fall to ~300 ohms at 100C. So either you have a defective sensor or your multimeter was on an incorrect range reading. I'd recheck your meter's set up and calibration and retest then make a call.
Old Sep 12, 2019 | 12:35 PM
B23A, that has carburetors? did it even have a CTS? or is this the sensor for the dash gauge ?
Old Sep 13, 2019 | 07:20 AM
rmmc's Avatar
It's for the dash gauge, I believe.
coolson
Aug 23, 2018 09:30 PM
Woc2
May 1, 2013 08:37 PM
blackbrick
May 7, 2011 01:46 PM
vimig
Nov 27, 2010 07:55 AM
hillfolk
Nov 26, 2006 01:05 AM
