Volvo 240 error code!
Old Aug 26, 2007 | 02:23 AM
wkboarder348's Avatar
Default Volvo 240 error code!
My girlfriend's240 gave the error code 2-1-4 for the ignition. The probable cause says ignition RPM signal erratic. It won't start and just cranks. It start once and was idling great and I put it in drive and it shut off. I couldn't get it to start again. Any help would be great! P.S. don't really have the money to fix things, hope its a simple fix
Old Aug 26, 2007 | 04:52 PM
VolvoDriver's Avatar
Default RE: Volvo 240 error code!
ok, so did you check the RPM sensor? when you get that code, it is usually traced to the RPM sensor which picks up and transmits RPM readings to the computer. you may need a new unit. check on top of the transmission right next to where the tranny meets the engine. The sensor is probably black, and connects, i think to the wiring harness above the firewall.
Old Sep 13, 2007 | 10:08 AM
how do you tell if the RPM sensor is bad?
660rider
Sep 28, 2014 12:41 PM
breachandclear
Feb 28, 2011 12:27 AM
Hownice
Aug 26, 2010 03:24 PM
throweasy03
Jun 14, 2009 09:43 PM
khesser
Jul 2, 2007 11:37 AM
