Volvo 245 rear supension springs replacement
Old Jan 12, 2006 | 10:33 PM
Red XC's Avatar
Default Volvo 245 rear supension springs replacement
Tech,
How do I take the old coil spring out of my 1991 245 wagon? I see a button nut, how about the top? I know I first have to compress the spring right?
Also, the rear shocks.. just squeeze the shocks and loosen the bolts? Any other suggestion parts I should change while I'm half way taking the whole rear end suspension apart? I will be doing this on the lift.. so any safety or instructions i should do
one more thing I see from ipdusa.com that the front struts are just a long piece of rod.. so I have to unscrew the old one, and screw the new one on??
Thanks in advance.
RedXC
Old Jan 13, 2006 | 01:55 PM
chris1kanobi's Avatar
Default RE: Volvo 245 rear supension springs replacement
With the rear springs you will just have to compress them and unbolt the springs. Slip the new compressed springs back in and you are ready to go. You can replace the shocks with the suspension unloaded. The fronts are a whole other story. You will need to compress the spring, swing the top of the strut out of the car and disassemble the strut (I removed the whole thing from the car for dissassembly) then you can change out the cartridges. If you have a pnumatic spring compressor, it would be alot easier (you can rent them at some rental places). It is a pretty big job to do without the correct tools. It took me about 6 hours to do all of the shocks and struts on my 89 240, with some help.
Old Jan 14, 2006 | 01:15 AM
Red XC's Avatar
Thanks!
So how many bolts are there to the rear spring? shocks, unloaded meaning just compressing?
Front suspension.. yeah I know they have to come out.. cartridges looks like a shock but is a strut with threadings?
850 GLT
Jan 26, 2014 12:17 AM
Volvo_Newb
Oct 18, 2013 01:33 AM
BrickMDXLIX
Jul 9, 2012 12:24 PM
carolinatrophy
Jun 5, 2012 07:09 PM
blackstarpower
Jan 3, 2007 01:03 AM
