Volvo 245 turbo No instrument, switch, or gauge lights
Old Feb 17, 2024 | 04:25 PM
2brick's Avatar
Default Volvo 245 turbo No instrument, switch, or gauge lights
Today I was changing the tiny bulbs in the center console gauges of my car with new LED ones. It was working fine until I put the last bulb in. Once i turned on my lights to see if all the gauges were lit, none of them turned on. I tested the gauges with a multimeter and found that none of the bulbs were receiving power. Did I accidentally break something? No fuses are out. Thanks everyone
Moving the dimmer switch makes no difference
Old Feb 17, 2024 | 04:57 PM
Test the power at the dimmer switch -
Do both sides of your parking lamps work?
The instrument lamps are fused with one side of the parking lamps (the bottom 2 fuses)
Old Feb 17, 2024 | 05:33 PM
2brick's Avatar
My right side parking lights are out. But the bottom two fuses are not broken and look okay.
Old Feb 17, 2024 | 05:58 PM
Whats the voltage at those fuses?
(Tag lights are on one of those fuses, and instrument lights on the other)
Old Feb 17, 2024 | 06:30 PM
2brick's Avatar
when I put the probes of the multimeter on either end of the bottom fuse, it reads zero. The one above it reads .03 volts
Old Feb 17, 2024 | 06:45 PM
That is checking for voltage drop - the loss of voltage due to resistance between where the meter is touching (positive to positive) If there is no resistance you will get 0 volts.
If you want to measure voltage, one of the leads needs to be touching ground (the body of the car)
One lead on a hopefully positive wire and one lead on a negative wire.
Old Feb 17, 2024 | 07:00 PM
2brick's Avatar
My bad. It reads 12V at both fuses.
Old Feb 17, 2024 | 08:00 PM
If your parking lights don't work on one side - and you did not remove any wires at the fusebox (to the non working parking lights)
then - how about a fuse that is damaged on the tip - have you tried a new fuse?
And power to the dash rheostat comes directly from one of those bottom fuses -
Old Feb 18, 2024 | 11:32 AM
2brick's Avatar
I picked up some new fuses this morning, so both slots have brand new fuses in them. Still no difference. Is there a possibility I pulled apart two wires when I was messing with the gauges?
Old Feb 18, 2024 | 02:29 PM
Should be able to trace power from the fuse to the dash light rheostat - then on from there -
Old Feb 18, 2024 | 04:44 PM
2brick's Avatar
How many wires should be connected to the dimmer switch? I took the panel off and I see 3 connectors on the dimmer switch, but only 2 of them have wires connected. one connector has red and white wires connected, the other has brown wires connected to it. Is it possible a wire was yanked off the third connector?
Old Feb 18, 2024 | 04:48 PM
2brick's Avatar
Is there supposed to be an earth on there? I see one on the wiring diagram
Old Feb 19, 2024 | 12:24 PM
2brick's Avatar
empty terminal
Old Feb 19, 2024 | 01:51 PM
2brick's Avatar
Update: Read online you can bypass the rheostat without serious consequence. I tried it and it worked! I’ll just put the rheostat back in unconnected
Psaboic
Jul 22, 2023 03:07 AM
beautiful-white-brick
Dec 10, 2021 12:02 PM
journeyforce
Nov 30, 2012 09:59 PM
volvo63
Jun 6, 2012 08:18 PM
lwrdr2
Aug 18, 2010 11:02 PM
