Volvo 87 240 over heating
Old Oct 16, 2007 | 06:29 PM
como71's Avatar
Default Volvo 87 240 over heating
My 240 I recently bought overheated and boiled over. I replaced the bottom radiator hose a little earlier (it had a leak). When I filled it back up it was running higher than normal. Any ideas?
Thanks,
Como
Old Oct 16, 2007 | 06:44 PM
Default RE: Volvo 87 240 over heating
Check and maybe even replace the thermostat if it is old.
Old Oct 20, 2007 | 07:44 PM
83242GT's Avatar
a coolant flush might also be in order to remove any junk floating around possibly causing a blockage.
Old Oct 20, 2007 | 09:19 PM
jorhyne's Avatar
These 240's can take a beating and keep going. I made a monumental mistake last week with my 240. My alternator went bad and I pulled it off and cut the belt off - was going to get a new belt too as the old one was bad- and drove to the parts store to get a new alternator and belt ( I didn't have any other way to get there). I left the car running at the parts store because I didn't want to shut it off with no alternator because the battery probably couldn't restart it. Well you are probably already thinking I was stupid. Yes I was, by removing the alternator the water pump will no longer be operational! I drove to the parts store 4 miles away and let the car idle outside the parts store for 10 minutes with no water pump! I happened to look outside and saw steam billowing from under the hood and antifreeze pouring out underneath. I had to then repair the car in the parking lot (I keep a set of tools in the trunk) which was not fun and embarrassing. Anyway I was worried the head gasket might be blown or something bad like that.
After I installed the alternator and filled up the antifreeze, it started right up and no problems. These cars are tough!
Old Oct 28, 2007 | 12:34 AM
buckquark's Avatar
como71 same thing happened to me. where do i take it to have the thermostat replaced?
Old Oct 29, 2007 | 12:03 PM
bigdaddyrdpjr's Avatar
buckquark 2 bolts hold the t-stat housing. Save some money and change it yourse;f
Old Apr 27, 2009 | 10:19 AM
jfreesprt's Avatar
Had a problem with my 1985 240 DL overheating. Changed water pump. Checked for coolant level. All was OK. It had seemed fine, coolant flowed AROUND but not THROUGH the Radiator/Engine. Turned out the Radiator wasn't good. Replaced. Ok now.
glover1968
Mar 11, 2007 03:12 PM
s80t6schcik
Mar 8, 2007 09:03 PM
Puma
May 8, 2005 08:23 PM
GJdP
Feb 3, 2004 08:03 AM
btchblock
Sep 22, 2003 05:26 PM
