Volvo 940 b230fk stalls when driving
Hi Volvo Forum
My 96 Volvo 945 suddenly stalls when driving.
Its a b230 fk
When driving normaly the car suddenly stalls and wont start again.
its idling fine, but when i start driving its hesitstats and suddenly stops. when i turn the key the engine is turning but wont start again. but after 30 mins it starts and idle just fine.
I recently changed the o rings seal in the injector because it was leaking.
new sparkplug and wire, new rotor, and distributer.
i think it may be a fuel problem.
Do you guys have any suggestion?
Sorry for my bad english.
Its a b230 fk
silvermine (04-12-2022)
Are there any codes retrieved from 17/11 the self diagnostic port? Or since it's a 1996 (we have obd2 ports in the US on a 1996) any codes found with a scan tool at the OBD2 port? Power problems (bad connection, cracked solder joint in a relay) will usually not set a code. Bad speed sensor will set a code. Ignition amp is hard to diagnose, won't set a code but is usually not erratic, unless it's a poor connection to it. . .
Marcopolis (04-27-2022)
This is such an awesome post. May I ask you where you got these diagrams, and where I might get them for myself?
I also have a 940 b230fk that lights up the Lambda light as soon as it is in warm running state. I do not have a diagnostic port (17/11), and none of the OBDII diagnostic devices I have tried works. The only thing I can do is try again after it cools, and disconnect the battery to clear the code.
Any idea what I can test, or which OBD reader works with these models? Its a shame I cannot use the car, and I suspect in is a failed component somewhere. I'm just at a loss as to which one it is.
I thought if I had a diagram like this for all the other sensors, and I could try to test each one of them.
untouchable
10-13-2009 09:27 PM
