Volvo 940 GL not starting
Old Aug 16, 2024 | 07:38 AM
Volvo_940's Avatar
Default Volvo 940 GL not starting
A Volvo 940 GL 1993 is not starting. It is getting fuel, but the spark comes when the ignition key is released and going back to the off position. Any ideas?
Old Aug 16, 2024 | 03:45 PM
With your noid light - do you have a pulse at the injector when the engine is spinning over? What is the condition of the wiring going to the crank sensor? What's the resistance in the sensor?
If your crank position sensor is not sending the correct signal - the ign coil may only fire when the key is turned on or off.
Old Aug 30, 2024 | 12:01 PM
Lilaji's Avatar
I had the same problem. Turned out to be a weak magnet on the crankshaft position sensor which is easy access on the transmission bell housing.
gjores
Mar 29, 2022 05:29 AM
Türk
Jan 24, 2017 01:54 PM
dhammika
Jul 20, 2015 10:23 AM
mark schaefer
Feb 10, 2011 07:39 PM
KSIMP88
Dec 23, 2006 08:23 PM
