Volvo 940 turbo smoke comong inside the car
Old Nov 20, 2008 | 05:13 AM
itufoi's Avatar
Default Volvo 940 turbo smoke comong inside the car
From the manifold the smoke is coming out from the exhaust pipe or connection pipe between the manifold and the exhaust and I don't know how is called. Ant there is I believe the turbo on the same pipe line. Anybody knows how to fix this? PLs help. I can not use thw heat and is winter.
Old Nov 20, 2008 | 07:30 AM
Default RE: Volvo 940 turbo smoke comong inside the car
Its hard to figure out from your words exactly where it is leaking but you might need exhaust manifold gaskets?
Old Nov 20, 2008 | 11:14 PM
itufoi's Avatar
I am sorry but I don't have mechanical background. Anyways, the smoke is coming out from the pipe link between the manifold and the exhaust pipe. I was told that there is no seal or gasket it is tapered fitting. Any idea?
Old Nov 21, 2008 | 08:13 AM
Something must not be set correctly then. Maybe a hanger in the rear of the car for the exhaust is bad. That would cause the piping to turn some and possible cause a leak.
Old Nov 21, 2008 | 11:21 AM
tedv's Avatar
I am pretty sure there is a gasket between the manifold and the pipes. Sounds like you need one!
Old Nov 21, 2008 | 03:54 PM
Some of the turbo cars didn't have a gasket it was only a metal on metal flange.
royalslover
Sep 20, 2019 02:43 PM
aecustomcars
Oct 31, 2013 07:33 PM
sdguy
Oct 4, 2010 08:30 PM
Brandy_l
Sep 9, 2010 11:52 AM
ccnavin72
Apr 3, 2008 08:50 AM
