Water gauge temp test
Old Apr 10, 2019 | 08:45 AM
Slo240's Avatar
Default Water gauge temp test
Hey guys.
Just bought a 93 240.
Its a good little thing, but I’m still figuring out it’s issues.
Ive noticed the water temp gauge barely moves off the lowest position. See pic attached.
I saw the previous owner replaced the radiator. In the boot there was also some chemi-weld.
Im concerned the radiator replacement was a quick and easy fix for a bigger issue and perhaps the chemi-weld is a safety measure in case it happens again.
My question is - how can I check the water gauge on the gauge cluster is representing what’s going on in the engine?
i live in Australia so ambient temperatures can climb pretty high so this is a concern driving a car designed for European conditions.
Anyone have any guides of how to check?
This is where the gauge sits - irrelevant of highway driving or bumper to bumper city in the summer.
Old Apr 10, 2019 | 09:45 AM
silvermine's Avatar
welcome and you should read this 240 Temp Faker
Old Apr 10, 2019 | 06:49 PM
Slo240's Avatar
Whaaa.. splendid mate!
Thank you!
Old Apr 11, 2019 | 06:09 AM
act1292's Avatar
Actually it sounds to me from your symptoms that your thermostat is stuck wide open or missing rather than the faker board.
Old Apr 11, 2019 | 06:59 PM
Slo240's Avatar
if it eventually got up to temp - I would suspect the same. But because it never moves - I think it’s not reading temperature.
Old Apr 12, 2019 | 05:59 AM
act1292's Avatar
When the thermostat is stuck open, it will not go up very much at all. When mine was stuck open, it wouldn't move past what yours is reading in the picture. When it was below freezing out, I could barely get it off the lower line.
Old Apr 12, 2019 | 03:35 PM
with the engine idling after sufficient driving to heat it up, take a IR thermometer and read the temp of the hose from the water pump
Old Apr 15, 2019 | 09:36 PM
Slo240's Avatar
The heater is warm.. not hot - but warm.
I have noticed the temperature of the air rising slightly - but not much.
May order a new thermostat none the less - no harm in replacing.
thanks guys
Old Apr 17, 2019 | 05:18 AM
that definitely sounds like a stuck open thermostat, so your engine is never getting up to proper operating temperature. your gas mileage is suffering due to this, fixing it should improve the economy and performance.
Old Apr 17, 2019 | 07:28 AM
silvermine's Avatar
and, of course if after removing it isn't obvious, the OP could test the existing t-stat in a pan of boiling water to see if it is actually working properly .. or not..
volvodriver99
Sep 28, 2019 10:33 PM
20cubed
Dec 30, 2018 07:58 AM
bctom
Mar 7, 2015 09:08 PM
SmrkngRvng
Jun 22, 2013 06:07 PM
93-245
Jun 21, 2010 04:44 PM
