Weird sound
Old Jun 10, 2006 | 12:41 AM
  #41
tupapison's Avatar
Default RE: Weird sound
exactly, im going to try to do it tonite, but i may not be able to see so i dont know if i can do it. imma go down right now brb
Old Jun 10, 2006 | 05:49 AM
  #42
tupapison's Avatar
well, i tried to do it, but i couldnt do it, i tried to pry it apart, but it was very hard, any tips?
Old Jun 10, 2006 | 09:53 AM
  #43
Big prybar or a Long Lugwrench.
Old Jun 10, 2006 | 09:23 PM
  #44
tupapison's Avatar
A lugwrench? hmm i dont get how will that do the job?
Old Jun 11, 2006 | 12:33 PM
  #45
Like the older style the really long ones with the screwdriver looking end on it. Stick it between the pipe and cover and pry.
Old Jun 11, 2006 | 11:24 PM
  #46
tupapison's Avatar
Ok, so i tried to do it, this time with a screwdiver and a hammer, i sticked the screwdriver in between the shield(where they are "welded" together) and started doing it, and i could do it, but i wasnt sure if i continued doing that the pipe would break or something, so what do you recommend tech? should i continue doing this? or just get a lugwrench and do what you said?
Old Jun 12, 2006 | 01:00 AM
  #47
Either one just do what it takes to get it off.
Old Jun 12, 2006 | 01:29 AM
  #48
tupapison's Avatar
But im afraid that if i do what i was doing im gonna puncture the tube
Old Jun 12, 2006 | 08:45 PM
  #49
The Exhaust pipe is pretty stirdy.
Old Jun 12, 2006 | 10:04 PM
  #50
tupapison's Avatar
K, ill try to do it tonite, well continue
Old Jun 13, 2006 | 01:46 AM
  #51
tupapison's Avatar
well, today i tried to do what you told me, and it was hard to do it, but i did it half way, and the noise is gone
Old Jun 13, 2006 | 07:37 PM
  #52
Cool see i said you can do it HE HE.
Old Jun 13, 2006 | 07:49 PM
  #53
tupapison's Avatar
Heheh, i mean now the sound is gone, but now there is a rattling sound, i guess its because the heat shield is loose,but ill fix it XD
Old Jun 13, 2006 | 10:53 PM
  #54
tupapison's Avatar
hmmmmm im going to take it to a muffle shop for them to cut it
Old Jun 14, 2006 | 12:31 AM
  #55
WIMP!!! LOL
Old Jun 14, 2006 | 05:57 PM
  #56
cbevis's Avatar
Serriously!? After a month of Monday's and 55 posts you're taking it to a dealer?! PULL UP THE SKIRT AND HIT IT WTH YOUR PURSE!!! LOL..jk, though i am looking forward to seeing if this works.
Old Jun 19, 2006 | 01:20 AM
  #57
tupapison's Avatar
Hhaahaa welllll arent you all special! Im taking the car tomorrow to have it removed hehe =] and also, my belts are a bit noisy, is there some kind of lube i can use so they stop whining?
I know there are several products out there, like belt dressings and stuff, but something from home? like WD40?
Old Jun 19, 2006 | 04:51 PM
  #58
tupapison's Avatar
Well, I took the car amd they welded both pieces off, but the SOUND is still there, the guy from the muffler shop says its a tube that's got a hole and thats why. Also im taking the car to the Volvo to have the transmission fixed(oil filter, gasket and oil....Because according to the volvo that's whats making the clunking sound i posted a while ago.
Also, i need to re-fill my coolant every 2 weeks, i think the container might have a hole, what do you think it is? should i just tell the volvo guys to fix it? along with the perforated tube?
Should i buy these springs? http://www2.swedishpartswholesale.co...=null&dp=false
Or the lowering ones from IPD? i mean i like the height of my car but what do you recommend?
Also i found a power antenna for $15 here in Panama, would it fit my car?
Lol check out my VIN info in carfax Y V 1 J S 8 3 1 5 S 1 1 9 0 8 2 4
Search Results: 0 records found in our database
Old Jun 19, 2006 | 06:16 PM
  #59
cbevis's Avatar
lmao....looks like you have a lot of things you want to do to your car! So many choices so little time eh?
I've been told that to get a belt to stop making noise you should check the pulies it's connected to. Don't spray WD-40 into anything...it's not a lubricant.
Old Jun 19, 2006 | 08:14 PM
  #60
tupapison's Avatar
ORIGINAL: cbevis
yeah i bought a spray "belt dressing"
"Well, I took the car amd they welded both pieces off, but the SOUND is still there, the guy from the muffler shop says its a hose that's got a hole and thats why. Also im taking the car to the Volvo to have the transmission fixed(oil filter, gasket and oil....Because according to the volvo that's whats making the clunking sound i posted a while ago.
Lol check out my VIN info in carfax Y V 1 J S 8 3 1 5 S 1 1 9 0 8 2 4 "
