Weird sound
Old May 24, 2006 | 08:49 PM
  #21
Default RE: Weird sound
Sorry no pics.
You see a pipe on the passenger side of the engine right?
Follow it down under the car about 2 feet and you will be there.
Old May 24, 2006 | 09:25 PM
  #22
tupapison's Avatar
Ok, i will try to do it tomorrow morning
Old May 25, 2006 | 12:53 AM
  #23
tupapison's Avatar
Hmm, i saw a "shield" but it was like a plastic shield or some other material but not metal, is that it?
Old Jun 2, 2006 | 01:46 PM
  #24
tupapison's Avatar
Hmm, I just arrived home and the noise was there, so i looked in the engine and i saw the pipe that you told me Tech, and im 100% sure it is the heat shield that is making the sound, but i still cant find it!! I was trying to find it under the car but no luck, what shall i do?
Old Jun 2, 2006 | 08:49 PM
  #25
Get better eyes!!
LOL.
Stand on the right side of the car with the hood open. Then look down There is a pipe that looks like this.
http://www.swedishpartswholesale.com...alker/1650.jpg
#31314 Follow it from the engine down under the car.
Old Jun 4, 2006 | 07:04 PM
  #26
tupapison's Avatar
Ok, i will try to fix it today! thanks
Old Jun 5, 2006 | 06:58 PM
  #27
tupapison's Avatar
Hmm on the RIGHT side of the car there is no pipe, on the left side(passengers side) i see a pipe going down, but i dont know if thats the one?
Old Jun 5, 2006 | 09:47 PM
  #28
Ok it is on the other Left side LOL Just kidding.
The side it is on is actually the right side of the car. When you stand behind the car and look foward then it will be the right side. Not when you look under the hood.
Yes that would be the pipe.
Old Jun 6, 2006 | 12:00 AM
  #29
tupapison's Avatar
Hehehe, ok so i see the pipe, but i cant seem to find the shield...
Old Jun 6, 2006 | 12:39 AM
  #30
tupapison's Avatar
Ok, i will take a pic of the pipe under the hood and i will post it tomorrow
ORIGINAL: tech
There is a pipe that comes off the engine. It drops down then turns under the Car. Where the turn is you should see the sheild. It looks like 2 peices welded together.That is the Sheild I speak of.
Exactly(remind me again) what am i looking for, is it like a circular thing? or is it 2 pieces of metal? or exactly what
Old Jun 6, 2006 | 12:49 AM
  #31
2 peices that are welded over the pipe. They are put over the pipe and tack welded in a couple of places.
Old Jun 6, 2006 | 01:00 AM
  #32
tupapison's Avatar
2 pieces of what? cicular pipe? long metal sheet? huh?
Old Jun 6, 2006 | 01:38 AM
  #33
Molded metal sheeting.
It is molded to look like the pipe.
Old Jun 6, 2006 | 02:00 AM
  #34
tupapison's Avatar
Ohhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhh, ok......then I THINK i know where it is, is it located just at the curve?
Old Jun 6, 2006 | 08:49 PM
  #35
One on the curve and one just after.
Old Jun 6, 2006 | 11:27 PM
  #36
tupapison's Avatar
Kk, ill try to check it tomorrow
Old Jun 8, 2006 | 03:12 AM
  #37
tupapison's Avatar
Ok, i finally was about to take that dam thing off, but im not sure how to take it off, i just use a screwdriver and it will fall apart?
Old Jun 8, 2006 | 08:41 PM
  #38
Pretty much. It has little Tack welds holding the 2 covers together. Pry apart.
Old Jun 9, 2006 | 11:02 PM
  #39
tupapison's Avatar
Problem solved! i took the car to the volvo so they lifted it up and checked everything under the car,they heard the sound also, and they told me that they would remove it for 20 bucks i said no way of course, but i now know which one of the 2 heat shields is doing the noise, is the one that is straight, and the transmission box was leaking, they said that the clunking sound i was complaining about was because of this, they are going to fix it, but they were amazed because of the condition of the car
Old Jun 9, 2006 | 11:42 PM
  #40
So you going to climb under and remove it?
