what is the best way to make sure new water pump dont leak?
Old Nov 4, 2008 | 08:38 PM
dads 740 turbo's Avatar
Default what is the best way to make sure new water pump dont leak?
The TOP rubber Grommet is my main concern, any tricks?
I plan to use some liquid gasket on there lightly to insure no leaks from the TOP Gasket "Grommet'
Old Nov 4, 2008 | 08:57 PM
Default RE: what is the best way to make sure new water pump dont leak?
The o-ring sits really tight.
I always use a very small amount of silicon sealer in the water pump before installing the o-ring(Seal) then a slight bit on the seal. I only use it to help slide the water pump in and move it to get the bolts in.
Old Nov 5, 2008 | 05:55 AM
tedv's Avatar
Actually the top ring rubber gasket almost never leaks. I put a little vaseline to help it up. I'd recommend you gently pry the water pump up with a large screwdriver to get the bolts to go in once the pump is on the studs and the nuts are hand tight-makes it easier.
Old Nov 5, 2008 | 07:25 AM
I use a small screwdriver in one of the bolt holes to move it around and get the screws started.
Old Nov 5, 2008 | 09:08 AM
Thank guy's...
The Pump & Timing Belt should be here today .
81sidewayswagon
Apr 11, 2010 10:37 PM
Bender
Nov 10, 2009 07:30 PM
j8kschneider101
Jul 12, 2009 07:31 PM
TimBader
Jul 12, 2009 01:01 PM
oxmanwi
Nov 28, 2006 10:10 PM
