What is the purpose of this part?
Old Dec 31, 2020 | 04:03 PM
Lucas Prochnow's Avatar
Default What is the purpose of this part?
I'm trying to take off the stock air filter on my 84 244 do as it is broken. I there is a corrugated pipe from the air filter to the exhaust pipe. What is this for? Do I need it or can I take it off?
Pipe going into the exhaust.
Pipe coming out of the air filter.
Old Dec 31, 2020 | 05:40 PM
lev's Avatar
lev
Sure, you can take it off! It's a preheater hose, does little, but in California the car won't pass a smog test visually.
Old Dec 31, 2020 | 06:08 PM
When the air box thermostat (in the air filter housing) that controls when hot air is sucked into the engine goes bad, it allows hot air all the time - which is not a good thing for your air mass meter. (I live in the south) So If you don't need it to pass an e test - (or you live in a cold climate) take it off/take the flap out of the air filter and block off the lower connection with a piece of crushed/clamped off hose.
In answer to your question - it's there to preheat the intake air - maybe to prevent icing. (moisture in the air freezes when sucked into the engine)
Cobden2007
Jun 20, 2020 08:04 AM
archetypezombie
Apr 16, 2013 07:37 PM
S40 Wheelman
Jan 12, 2011 07:09 PM
kzs983
Oct 23, 2008 09:21 PM
knight rider
Jun 26, 2005 09:10 PM
