What is this warning light?....
Old Jan 12, 2006 | 09:06 PM
jet wrench's Avatar
Default What is this warning light?....
What does the yellow warning light to the left of the cluster indicate when illuminated? It looks like a gear with an exclamation point in the middle. It illuminated intermittently when I braked hard. It's a non ABS car, a 1991 740. It seems to have a soft brake pedal. The car sat for some time. Thanks in advance.
Jet Wrench
Old Jan 13, 2006 | 01:59 PM
chris1kanobi's Avatar
Default RE: What is this warning light?....
Have you checked the oil and transmission levels? I have not seen that light, but my guess is it is low transmission fluid level. When you step on the brake the fluid splashes around. Just a guess. The owners manual should tell you what each light means.
Old Jan 13, 2006 | 02:46 PM
colgate41's Avatar
It might be the warning light to tell you that a bulb is out. i.e. a break light does not work.
Old Jan 13, 2006 | 08:18 PM
ldf602's Avatar
I have a 1989 740 and am looking at the owners manual warning lights. I see nothing that looks like a gear. My only symbols are an oil can, a battery, a lightbulb with an X thru it as stated above, and a low washer fluid light that looks like a windshield with a little fountain in the middle.
Old Jan 13, 2006 | 09:53 PM
Is there anyway you can post a pic?
97-850Wagen
Sep 10, 2013 10:40 AM
TDolce
Oct 26, 2007 05:52 PM
Gordon
Jun 28, 2007 09:26 AM
andy2812
Jan 22, 2005 12:32 AM
fopdod
Jan 18, 2005 06:45 PM
