What Year Fuel Pumps can fit on 1993?
Old Oct 20, 2013 | 02:14 PM
floz313's Avatar
Default What Year Fuel Pumps can fit on 1993?
ok i have been searching the internet and fuel pumps are not cheap around 200-450$ and i was considering going to a junk yard but i can not find my exact model 1993 940 volvo and i was wondering what other volvo model fuel pumps can i take and use on my car instead? thanks
Old Oct 20, 2013 | 04:36 PM
you need to know if the car has BOSCH or REGINA injection.
regina uses only a single high pressure pump inside the gastank, and no pump under the back seat. bosch uses both a booster pump inside the gas tank and a high pressure main pump under the back seat (these are on the underside of the car...). turbos and 16V's came with a higher flow main pump, this higher flow pump could be used on non-turbos without any problems, but the 'normal' flow pump wouldn't provide enough gas for the turbo engine under heavy boost/acceleration.
the last year of 940's, 1995, even the bosch cars switched to a single in-tank pump, which happens to be the same in tank pump used on 850's and newer cars.
within these constraints, a bosch non-turbo 2-pump car could use the main fuel pump from *ANY* 240/740/940 non-turbo/non-regina from about 1983 forward. I think the 240 and 740/940 in-tank pumps differ somewhat.
SlickNerd
Feb 15, 2011 10:59 AM
rmensah
May 31, 2010 09:54 PM
hairyg
Jul 15, 2008 12:23 PM
junkmorning
Sep 8, 2006 05:15 PM
whyflygti
Sep 26, 2005 12:42 AM
